VGA to TV Scart
source:
unknown
THE CIRCUIT
Note :
this circuit is auto translated from the Greek
version
This is a circuit
converter from VGA in TV SCART connection. Basically it is a circuit
that accepts the signals from the exit of card VGA, him it then
changes in combination RGB+composite sync and it leads to fastener
SCART. The elements of picture from her exit card VGA, RED, BLUE and
GREEN are already ready, bring right tendency the 0.the 7 vpp and
right resistance of 75W for direct connection with fastener SCART, for
depiction in the TV. What should it changes it is the right
combination the horizontal and vertical synchronization signals from
the VGA in a complex signal that will be led to the entry VIDEO in pin
SCART. This transformation him they undertake electronic elements of
circuit.
THAT IT FUNCTIONS
This circuit has been
drawn in order to it changes regular signals VGA, standard RGB and the
complex signal of timing. circuit is simple because signal RGB from
the VGA is ready in
standart
level 0,7 Vpp and in 75W charge. For the signals of timing exists a
circuit that changes the horizontal and vertical in complex. The
circuit is simple based on a TTL completed with four gates XOR, two
resistances and two capacitors. His choice completed TTL it is
reasonable because the signals of timing of VGA they are signals TTL.
The converter of signals of timing is system that regulates the
difference of polarity of signals, so complex signal it is always
right. Card VGA uses different polarities in the signals of timing in
order to it informs the Monitor anymore analysis it uses. This circuit
regulates the changes polarity the signals in least from 200 mSec,
that are faster and from the time of regulation of common Monitor VGA.
The circuit in order to function need stabilized tendency + 5V (+/-
5%) and current 120mA.
MANUFACTURE
Converter VGA in TV is
easy in the manufacture to him it is enough exists a relative
experience in the manufactures electronic. The circuit can be
manufactured on one small EPOXY board. Remember only to connect also
the completed circuit with the catering of 5V (in the drawing it does
not appear). The circuit in order to it rightly functions it needs
without fail stabilized tendency consequently it should you use also a
REGULATOR LM7805. In the entry the 7805 the tendency should be from 9
until 16V so that it accomplishes us it gives the desirable stabilized
tendency of 5V in his exit. Tendency from 9 until 16V we can him take
also from our computer or from exterior small power supply's socket.
From the computer we can we take from the following points: from door
RS232, from the parallel door , from the PS2 and finally from a
gambling chip of catering by his interior computer. Big attention
should be given in him you stick that you will make and in the wiring
of circuit, you avoid the chills you stick why the circuit functions
in big frequency and sure will be created instabilities in the circuit
with result bad quality of picture or even lack timing in the screen
of TV. Be careful in order that the soldering is clean and glazing
thus you will only be sure that the soldering has become right. For
the wiring you are used shielded cables blentaz and ground the thorax
of cables in the board's chassis. Good it is manufacture it is placed
in a plastic box and it is placed and a connector EURO/scart female
for placement in
chassis.
Good success.
MATERIALLY
